Attacking a slightly different animal with a zeal this summer. I am running a Zealtronic on a KV997. The KV flywheels and pickups are compatible. Havent had it in the water yet but she is running really nice on the stand.
There are some changes from the commonly used 760 set up.
The Static Angle of the KV997 is 40*
The wiring is as follows.
Zeal Wire=Krash Wire
Red=Red
Orange=Orange
Blue=Blue
Black/White=White
Green/White=Green/Yellow
Black=Common Ground in ebox
Brown/Green=Ignition Map Switch (optional)
Also the peak advance of the KV997 stock CDI is 28*. I am starting out using the wax curve. With its peak of 32* I will be starting with a 135p 125m fattened up from the 125p 135m found standard on these.
Sharing to help the collective mind. Any constructive advice or comments are welcome.
Sent from my SM-G965U using Tapatalk
