waxhead
wannabe backflipper
- gold coast
if you do a reverse calculation of the info that yamaha gives you its 60 ft pounds
Transfer area and flow was a big thing in making power. Making the ports flow was a big part in making power.
2 second pull i did see 124 lbs
Full spec 49's over stock 46's 10 hp in the upper mid to top
from 170 psi domes 14.5 pump to 16.5 190 psi domes make 8 -10 lbs all the way through. But you need C12.
ET mani 20 lbs from 5-6k and 8 lbs from 6-6500 and same on top as stock PF mani from 6500 to 7200.
I agree with you BK, but the flip side to that is all of the "bros" who are judging and hyping a platform by how hard it "rips". While I agree that the dyno isn't the end all be all, it could at least provide empirical data in an arena that is dominated by hype. I don't particularly care about a top HP number, but seeing the torque curve or at least having a peak torque and RPM (as Etech provided) I find useful.
Product looks great Art! Will there be one in a demo hull at Daytona?
Seems some of these other people are not bound by the law of physics as the rest of us, Im glad to see you write that I have been saying the same thing for years.As for 200 hp not one will make it not even 1200 or 1400 with a single pipe and this low rpm. 49mm carbs flow as much as a 42mm round slide carb. second a single pipe with a 41 mm stinger will not flow 200 hp sorry. CFM = HP without supercharging it is not possible. A small stinger will make quick power on a bigger engine but if held wide open too long it may go boom! must add more water to keep it cool to keep the frequency down.
All these engine use the same pipe and carbs. The bigger engines will make more torque and a bit more power.only a percentage not a 50 or 100 more HP more.
There will be more hp as after the ET mani and there will be a ET pipe for sure.
Here is some info on cranks, light T crank make more low end at 5-6k 12 foot lbs more than the full circle. The full circle make more at 68-7000 5 hp
The reason is the volume change, more case volume less pressure, makes for more lowend power( doesn't get blow out the ex).
For example i have built many Sled engines 1160 billet 78mm x 98mm huge ports 6 port intake 3 huge EX ports 48mm round slide carbs twin pipes 36mm stigers custom timing curve 15:1 comp 205 hp at 8000 still to this day will out perform others that claim 240 hp
Some may even know about my ET F9 Billet cylinder kit for the F7 Arctic Cat 151 mph 8:70 1/4 mile 890cc BD noss still to this day record sled on the tar under 900cc.
Some more info ya.
Yes it was bored.How about some 62t/61x stock bore numbers for us everyday weekend warriors.lightened fly wheel do much? Bore the bpipe mani out to 49/50mm?
Have not tested should be close. I will be testing the boyesen intake soon.When you look at the one just posted above.
The b limited chamber, 44s and an msd you see your getting a massive gain in torque.
Thats a great setup makes me wonder why other people have no recomended this setup to people before. Or maybe they have but people were to blind to read it.
What I would really like to see is if you have the data between the v-force two reeds and the v-force three
