- Cruising Around
Told you guys last year to watch for this guy and his motors
That all depends on hot pipe or cold pipe. long pulls or 2 sec pulls. The hp for freestyle is quick power mostly in the mid from 4000 to 6500 and you also need the over rev up to 7400. HP is not what we need it is tourque! I used my dyno as a tool to find power after small and large changes in the cylinder ports,angles, widths and heights.What was the HP on the dyno?
62TGreat to hear a cast mani coming to the 66e platform![]()
Many hear believe knowing the HP and Dyno results is the end-all test on a motor....................... They do not get that the dyno is just a tuning tool and nothing else. It does not matter if a motor makes 200 hp if you cannot get the 200hp to the pump and at the point where the pump is efficient.........That all depends on hot pipe or cold pipe. long pulls or 2 sec pulls. The hp for freestyle is quick power mostly in the mid from 4000 to 6500 and you also need the over rev up to 7400. HP is not what we need it is tourque! I used my dyno as a tool to find power after small and large changes in the cylinder ports,angles, widths and heights.
Also combustion chamber design to maximize torque and also have the power on top.
The water cooling ports and flow in the cylinder and head design also played a big part in making constant power after long rides to prevent heat fade.
I will wait to post any dyno sheet or hp # until there is a full comparison to all the other engines on the market.
Transfer area and flow was a big thing in making power. Making the ports flow was a big part in making power.
2 second pull i did see 124 lbs
Full spec 49's over stock 46's 10 hp in the upper mid to top
from 170 psi domes 14.5 pump to 16.5 190 psi domes make 8 -10 lbs all the way through. But you need C12.
ET mani 20 lbs from 5-6k and 8 lbs from 6-6500 and same on top as stock PF mani from 6500 to 7200.
Totally agree, and if you look at the stock cylinder and see the angles you will see it tries to force the rising coloum of air out the exhaust port , terrible design.Wall friction is one thing but it also need direction to get a good burn pattern correct!
