Alright just to keep things updated, I've made a decent amount of progress at least in my opinion with the hull. I ended up glassing over the hole where a scupper valve would've went, I'll just run one or two bilge pumps and have less possible failure points. Also have the thru hull exhaust pipe permanently mounted. And then finished filling the footholds with foam and glassed over it. It's officially ready for paint as of today and will hopefully have the top half painted next week sometime.
Other than that it's just a matter of ordering things when I have the money. I still need all pump components and cables. Then to figure out what I'm going to do with the motor, definitely running an ADA girdled head and Factory Pipe, but I'm still undecided on if I'm going to swap in 61x cylinders and give a DIY porting template a go or just run the 62t untouched.
Here's some update pictures, I'll take some more tomorrow as I thought I had more.
