Quinc
Buy a Superjet
- California
Impressive! One footed too!
It's a lot more fun that way! Finally getting comfy to start trying new things. It's tough riding out of one footer 180s though.Impressive! One footed too!
It's a lot more fun that way! Finally getting comfy to start trying new things. It's tough riding out of one footer 180s though.![]()
Gotta get him a set of superflip bars so he actually looks like he knows what he's doing!!
Guys, quick question. I'm riding in sub freezing temps tomorrow. Immediately afterward, I know I need to flush with antifreeze. Lemme know if this is the best way:
Run ski to get most of water out. Pull off cooling line on head, attach some hose with a funnel, and funnel it into the cylinder jacket. Then, funnel it into the headpipe, then funnel it into the stinger. Then loosen flow control valve, and idle/slowly Rev it through the system? Or am I over complicating this?
Thanks for the response! My theory is that if I fill the areas with antifreeze, and I start the ski, won't the cooling lines have enough pressure to slightly move the antifreeze through it? Or will that not do a thing since the pump isn't hooked up. Otherwise, funneling in antifreeze and then blowing into the hose would endup moving the antifreeze through the system I'd think..I don't know anything about this but the way you have it listed you'll have no flow. Either the pump has to be in water or pissers hooker to a garden hose to get flow. Either way I'd think the water would flush the coolant right back out and you'll be right where you started again.
At Pismo I flushed my ski on the beach with a 5 gallon bucket and hose hooked to a biliage pump that I put in the bucket. If you did this as well but put a 50/50 mix in bucket instead of water you could replace all the water in your engine with 50/50 coolant mix
You could also attach some fittings to the buckets side at the bottom and hook hosees from there to your cylinder head or where ever you decide is best. With the bucket held above the ski the weight of the 50/50
Mix will push coolant thru your system.
Now that I've thought about this maybe the way you propose to do it might work too. You'll have no flow but could still possibly get A mix going. Poor 100% coolant into head to mix with the water already stuck in the jacket and then the same to the head pipe without filling so much it backs up into the cylinders.
Bars to chest Rosie.. Bars to chest...This kid wont stop!!
That's not a good pic of form, I had some way better ones today! Also got a 180 hop pretty much all the way around today too. Pics coming soonBars to chest Rosie.. Bars to chest...
Looking back I definitely don't have the bars to my chest but I'm definitely yanking on themBars to chest Rosie.. Bars to chest...
