Freestylegeek's squarenose conversion
freestylegeek
waiting...
Grand Rapids, MI
By the way, the ski is completely turfed. Chad (DancesWithSuperJet) and I pulled it off in about 4 hours. I'll post some pics later tonight.
The new cases are ready for epoxy, and after that sets up, I'll port them.
freestylegeek
waiting...
Grand Rapids, MI
Turfed, siliconed, and sanded.
I also got the pivot bracket, hood hooks, and hood latch mounted up.
One more week!!!
freestylegeek
waiting...
Grand Rapids, MI
Is it done yet...
It's close my man!
I just got the steering cable yesterday, and all I am waiting for is the pivot bolts for my handlepole - which are en route right now!
If I get them today or tomorrow, this puppy will be D-U-N DONE!:arms:
Now, the stroker motor on the other hand is a different story...
More on that at lunch.
Y
yamaslut
Guest
It's close my man!
yes... we will neeed a full report at noon.. thank you
:biggthumpup:
douglee25
m3booooy
South Jersey
i have spare pivot bolts at my house if you don't get 'em for whatever reason i can ship out to you asap. they actually belong to wavedemon, but i'm sure in the spirit of daytona he'll let you borrow them for a few weeks! (i have a signed power of attorney from wavedemon, i can do things like this)
:haha: :haha: :biggrin:
Y
yamaslut
Guest
nice... :biggthumpup:
WaveDemon
Not Dead - Notable Member
Hell, Florida
uhhhh, ok. I won't be using it for a while.
freestylegeek
waiting...
Grand Rapids, MI
Dude, you're awesome, but if Patrick shipped them when he said he would, his will get here before yours. I think I'll be ok, but THANKS for the offer man!! :cheer:
freestylegeek
waiting...
Grand Rapids, MI
Lamey Stroker motor
:biggthumpup:
OK, I'll keep it short.
The crank I have is an 8mm RAD crank.
It has the triangle webs and is the lightest crank out there.
The front bearing must have seized on it at one time and spun on the spindle, therefore reducing the diameter of the spindle. A new bearing was pressed on, but only had an interference fit with about 1/8 of it's length (near the web). When I pulled on the bearing to check it, it slid about 1/8" axially down the spindle - not a good sign for a press fit. So, I jumped on the phone and called Jason at Crankworks. He said it sounds like the bearing surface on the spindle it worn. He also informed me that the crank I have is pretty neat, and that since RAD is out of buisness, those webs are pretty much unobtainable. - CRAP.
He did mention that if the gap bewteen the bearing and the spindle is around 0.001" some green loctite (sleeve retainer) would do the trick.
So, there's hope. It's at a machine shop now, and should be pulled this weekend, then I can check clearance. I also looked up the data sheet on sleeve retainer and found that it will fill gaps up to 0.007" diameterally!!!
I am now suuuuuuper confident I will be OK with this.
All that said, if I were to solve the crank problem, I still would need to order a custom thickness base gasket or new domes to drop the race gas compression the motor came with. THEN, if I got ALL OF THAT taken care of and got the motor in, I would have to set my total loss timing down in Daytona. This is timing I have NEVER delt with, and has the ability to destroy this engine. As if that wasn't enough, I would have to tune my NOVI 48's as well as my pipe and water routing in conditions that my boat will only see once. I think it would have been an excercise in foolishness.
So now, I can go to Daytona and not have my head in my hull all weekend.
I will actually get to ride and talk to people, and have an AWESOME time!
