If you are used to a 1911 trigger the LDA is going to be different for sure and the mechanism is complicated no doubt. I felt the trigger pull was acceptable for what it was designed for. Matt- slide cracked wow not good, had'nt heard that before. I only suggest the DAO in a CC situation because of the litigation that comes along with defending yourself. Attornies love to use the term (hair trigger). That helps them make you look bad and the guy that was causing you harm look defenseless. I've had few (I always buy in pairs) Para's, Sprinfeilds, Colts,Kimbers etc. I currently own a pair of STI Tactical 5.0 45's that I picked up recently and am probably happiest with them. I do not CC with them and do not train enough with them so they just sit for now.
