tom21
havin fun
- clearwater FL
did I miss something or did that post just disappear?
Yes, yes sir I did. And I am not trying to start anything, I don't know the people involved personnally, have done business with SBT with no issues, and am in every way possible that I can think of not biased. I just want to understand how someone with obviously way more technical skill than is necessary can find that they cannot fit the crank properly and then SBT cannot find the SAME thing. If the crank fit with no issues why did they not just drop it in and ship it back with a note saying,"here it works"? If it was bad, why not tell us what the problem was?
Sorry to keep dragging this on and I apologize if I missed, forgot, misread, or plain just don't see that it was spelled out already. I am just trying to understand what the PROBLEM was. There must have been one if they sent a totally different crank. right?
what will happen on the next episode of 'as the crank wobbles'?
JESUS CHRIST!
who has these install problems with cranks??? this is ridiculus! seriously.
Scott,
Here's what we found:
1) The crank dimensions are fine. The laby is OE Yamaha and measures exactly the same as the 50 or so we measured last week (2.835"). All of the bearing OD's also measure good (2.834").
2) We cannot make the crank "rock". We case checked it in your case and our own test case and we find no problems with it. The holes in the bearings are within spec and are not interfering with the case pins.
3) The case halves you are using are in pretty bad shape. As my technical manager said, "we throw away cases better than that". We are going to try and clean them up for you. You have a lot of deposits and corrosion on the bearing surfaces that could be causing some of the "rocking" you have been noticing. You also have some hardened case sealant on the rear seal surface of the lower case half that needs to be removed for the seal to fit properly. We will get it off for you. I personally think the condition of your cases might be contributing to the engine failures that you have had.
4) You have one pin in your case that is ground flush. I realize that you mistakenly ground that pin flush after talking to our tech guys and we will put a new pin in it for you.
5) The end bearing on the crank feels a little rough to us (like there may be some debris in it) and we suppose it's from one of the previous engine failures. It probably would be OK, but we are going to utilize our one year fault free warranty policy and give you another crank.
6) So in summary, you are going to get a new crank from SBT and we will give it our best shot at refurbishing the case halves that you sent to us. We will test the new crank with the refurbished cases and make sure that it does not rock before shipping it back to you.
Thanks
Greg Pickren
SBT
Ewok, I see that GP put up what they measured... what is the measurement you came up with, the same? larger?
They also could not get it to rock, possible some chit was in the hole or junk on the case? oops I see they said it was crusty. maybe that was it? Not knocking just asking.
didnt measure it...I could tell just by looking at it that it would fit......opened it up, and it dropped right in.....
now we have to deal with the locator pins.....
