ice's freestyle squarenose project
IceRocket1286
Metro Detroit
soo i got bored tonight, made myself a flush kit out of some hose and a hose adapter thingy lol.
the yellow hose attaches to the head, and the other half of the T attaches to the line from the pump. When i need it ill use it, when I dont it wont be on.
if one side is on the head and the other is on the pump, youll be:
1: sending water into the hull from the nipple on the manifold
B: wasting half the water backflushing the pump and
III: wont be flushing the pipe (unless you have dual cooling and you use the secondary line.
IceRocket1286
Metro Detroit
whooops i explained it wrong.
It will be hooked to the head, and then Ill hook the other end of the T to the hose that WAS on the head.
Im a dumbass
Im a dumbass
ahh, much better! so youll be TEEing between the head and pipe. thats better.
ski looks great! nice clip-art babe on the pole.:arms:
IceRocket1286
Metro Detroit
thanks
trim system is a pro tec trim ring/cable/through hull tube, moutain bike brake lever, and raider steering nozzle/red nozzle.
i dont understand ur turf question
did you turf over the stock plastics on the rails . can i see a picture from behind the ski at the pump? my friend is trying to do his.
IceRocket1286
Metro Detroit
2nd Nature I just noticed your post now. No, I didnt turf over the stock rails. I took them off and turfed it as it was.
From the back, it looks just as you would think, I cut and folded the turf around the corner and up to the tray, simple.
On Another note, my project is DONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Heres a pic of the motor with the carb finally on, and a pic of my finished trim system throw.
