madscientist
chilling with these guys.
- good old p'cola
yep ^^^^^^^^^^^^^^^^^^
it works
it works
I am not in the habit of taking up for Wad but he is correct about CDI-coil combinations,Seadoo uses them on all the 580's and 720's they produced,my Suzuki four wheeler also has a combo CDI-coil.
I am not disputing that. Seen and worked on them myself.
Just poking fun at how "a coil works as a capacitor." :biggrin:
Travis, to cut to the chase: A Capacitive Discharge Ignition uses capacitors and diode circuits to double voltage several times (up to 400VDC) and then dumps that into the primary of a coil.
A CDI cannot work without the caps.
You can still have a valid ignition, but it won't be CDI without the caps.
Well this thread is still worthless lol
my my, arent' we opinionated.
UUUMMMM You just figured that out ?
Riveting entertainment. I can't wait to see what happens next.
yes, an up to date type.
just because the system is referred to as a "capacitive discharge ignition system" doesn't mean there's circuitboard capacitors as work in it.
Holy Crap Dude lmao this discussion ? But hey have fun, I guess if I dont like it I should just move on. it was a (hot topic) so I read it wasn't very impressed either lol.uhmmmmmm well, I happen to have my own opinion, too, I think you're closed minded to how much a discussion like this is actually worth. it may not be worth much to you, however, I'm sure everyone doesn't share your perspective.
So what does a TL system with out actually using TL and a capacitor isnt actually a capacitor BS have to do with an impossible to build indoor wave park jet ski thing?
Im confused :dunno:
:werd:They're all brain-children of Travis.
Do I need 1 or 2 gallon size jugs to fire a 701??
Matt E is correct. A coil itself is not a capacitor. It lacks the ability to store electrical energy like a capacitor. Disconnect the battery, and it can no longer function. A capacitor can release the energy it has stored after the power is turned off.
Im confused :dunno:
