- Jacksonville, Florida
Steering update
cleaned up the bolts to the umi system...may go with the UMI steering and pick up a rebuild kit from JSS...see below
I decided to run the blowsion phat clamp plus UMI steering instead of the x-metal steering + bars.
I want to run some riser bars for adjustability
Problem is that the steering plate that attaches to the Blowsion phat clamp wont work with the x-metal pole
( steering plate info: UMI Steering plate/setup YA-14104)
Does Xmetal make a fat clamp system?
( i found this one>>> http://www.teamxscream.com/products/index.php?main_page=product_info&cPath=36_29&products_id=6567)
OR
Is there a different turn plate that will house the blowsion phat clamp but work on the x-metal pole?
OR
