- Jacksonville, Florida
pics from this weekends progress
had to install a new 'used' manifold sent from JM...i got an easy out stuck cause I drove a bolt in too far...
Reinstalled the vf2's using lock washers and loctite...greased up all gaskets with marine grease...this makes it easy to change out the next go around and prevents corrosion
Installed JSS ebox with new screws that came with the kit.
