Hi
I am about to cut the holes for the steering and trim cables, etc to go through my SF hull and just want to check something with you....my sense is that the holes might work out better if drilled in front of the pole bolt to facilitate a more relaxed route for the bend of the steering cable. ...Did you see any issue with your cable bending in front of the pole bolt ? Any comments on what the other guys have done....please chime in ...I only want to drill these holes once. Thanks again for your help so far in documenting every step.
btw....if you ever in Cape Town, it will my pleasure to take you riding in our surf, which gets big as houses every other weekend....just bring a wet suit...water is cold about 50 ish degrees
UMI throttle is larger to accept the JM large throttle cable...
kvpi was too small
starting to run my cables as well
View attachment 218697View attachment 218698View attachment 218699
