went over all bolts on the engine
torqued ada head
gapped and installed plugs...torqued with anti seize
replaced most flat washers with lock + used marine grease
new flywheel key, new flywheel bolt
lightened flywheel installed
bendix + washer installed
JSS stator installed with lock washer + loctite
ran battery cables
installed cooling barbs
installed flywheel cover(greased both sides of the gasket with marine grease...makes for easy removal/change and prevents corrosion buildup. Did this on my last ski and it worked great.)
+ more stuff as you can see in the pics...
pretty much ready for drop in except for the carbs
COLD FUSION FLYWHEEL LOCK/HOLDER:
Worth it's weight on gold...must have for the tool box...makes things effortless
