Super Jet LegDrag Lightweight SuperJet Build
air blair
you are the reason
Guaranteed to splash you in the face, shawns got a mold of my tubbies to. Best out there imo. Real sick build. Good job
Sent from my SPH-D710 using Tapatalk 2
air blair
you are the reason
Figured u wanted to see a different rocker look with tubbies
MikeyB
H2O-Addict®
Michigan
Well my fixed steer square should be at the Daytona free ride if you're coming to that. You're more than welcome to give it a rip
That would be sweet, I'm going to try flying down there depending on how things are with work.
Good work, my only suggestion would be to start the rocker back a bit farther. I started mine just in front of the motor mounts. Looks really good though!
My only worry with starting the rocker back further is loosing the ability to fit my cold fusion tank. What type of tank are you running?
MikeyB
H2O-Addict®
Michigan
Had a buddy come by earlier and help me set the motor in so I could mock some stuff up and get a better idea of how far back the rocker can go. Im going to section the bottom deck back to the line I have circled and see how that looks next.
The motor is sitting on a set of couch mounts and I think it lines up pretty good. Not sure whats going on with the waterbox inlet though, I would like the flange to sit flush with the pipe so I guess I will have to modify that and have it rewelded.
MikeyB
H2O-Addict®
Michigan
Didnt expect that! Cutting an inch or two off the inlet would probably suffice but I would rather have it line right up. The outlet is pretty close to the hull but I think it should work fine in here.
MikeyB
H2O-Addict®
Michigan
Finally cleaned my garage then did some more cuts in the bottom deck and sectioned the rail up front. I'm liking this shape much more and might finalize it at this. Any other opinions? There is a bit of an underbite and the bottom deck hangs out a little more than the top deck, but I'm thinking I will leave it like this so the rail isnt as wide underneath if that makes sense?
