I may have made a mistake in not explicitly stating the hull will be glass. while there are some vinylester resins that can be used with carbon, they are nearly the same cost as epoxy and nearly as good. so it makes little sense to not use epoxy with carbon.
this hull will be glass. it will be slightly heavier than the carbon hull I made. this is an attempt to get as many hulls out before daytona so that they can be tested and hopefully with feedback changes can be made of if not needed I can focus on other aspects and projects.
sorry if that was misleading as the first hull was made from carbon.
A few fx guys rode the ski the plug was made from last year and gave it the thumbs up, so I can only imagine that a lighter than stock weight will be more fun than the stock hull+all the grafts(tray, tubbies, shave nose, pump install, wider rails) I will try to get a weight on that hull as it is now being used to build the carbon hull. I have been waiting til it was complete to start this but at the pace its going I will miss Daytona this year for any other hulls. So im sucking it up and throwing it out there to get some hulls under some feet and get this going, finally!
