Merry Christmas Updates on my progress
With the Hull flipped over we could clearly see the stainless bolt was cross threaded into the brass fitting. The easy out actually broke !! We then drilled it out and re-threaded the nut cert. Picked up a new bolt and all is well. Was thinking about using some 3M 5200 around the nut certs as I think they are developing some play??
A little out of order - but pulled the hand pole
Pulled and cleaned the disgusting bilge strainer -
It was super nasty underneath
My new TDR waterbox arrived
Starting to pull all the trim and pads -
Question ????
I am going to order the non foothold hydro turf kit.
What do you do about the existing storage and fire extinguisher holes? I can I reuse them ?
