Super Jet Newbs first ski build. 90 SN
swapmeet
Brotastic
Arlington TX
The top deck of a square is super thin stock. If you get a lot of air and land wrong or have some bad roll landings (which I think are required before good roll landings LOL) you'll likely crack/ break something. Defintely do a layer of glass or Kevlar IMO.
Local rider is going aftermarket because of how many times he's cracked his reinforced SN... Tired of fixing it. Which is worse, doing the work now while its cold or having to patch up your ski mid-season?
GL, build looks great.
I will be moving the pole bracket forward so any bracket will work if you know of any other dual breathers. Here is some more pics
Starting to get ready for the rocker
Tray glassed. resin with microballoons on the hood ready to sand.
Top end off the 62t. Waiting for gaskets to put the 61x cylinders on.
Cool thanks for the link. It will be at least a month before I order a bracket. I have a friend who has a stock bracket to use for mocking things up. I'm probably going to have to order more supplies soon. Lol that tray used a lot of resin making.
Yami-Rider
TigerCraft FV-PRO
Texoma
Lol and I knew this would happen but the day after I order my new rrp pole they post the new version that is almost 4 pounds lighter
That version has been used by few pros for the last year or so, idk about all that aluminum cut out...looks kinda weak.. Did you order the RRP pole for RN superjet?
looks nice and when converted to us dollar it is only $174. I wonder how much shipping to the us is though.
Also a question I have on the build is for the rockering. For making relief cuts on the bottom to bring it up is it better to make the cuts going across the ski or long ways going with the ski?
Thanks. Yeah I have seen a lot of people do it across which would give you shorter cuts and more cuts. Then a lot of people in our group are doing it long ways which gives less cuts but much longer cuts. Not saying either way is wrong. I just want to see what everyone recommends. I am kind of leaning towards the across cuts
