- OR
I do have an extra straight tube. I suppose it would be way easier to clear when straight.As Brapperdoodle mentioned, the lines from the pump bulkhead to the engine bulkhead should always be straight. "STUFF" will always ruin your day when "it" gets caught up in a bend somewhere. Not trying to ruin your day here...You might be lucky and never have a problem.
My trim/siphon tube is stainless, and my cooling lines and exhaust are aluminum McMaster said they had high corrosion resistance.I used pour foam in my first time around (bad move). Thinking I knew what I was doing, I re-used the factory aluminum cooling and bilge lines. Electrolysis and corrosion took over and created some new pin holes which in turn filled up that area under the floor mat when I was riding.
When opening my tray all of my original lines where still good and had no corrosion. However they were too short so I had to replace anyway.
I suppose the exhaust line and cooling lines should last another 20years now that they’re new?
. I had to cut the tray area out and DE-FOAM again. Replacing the OEM aluminum tubing with stainless. I ended up using 3/4" pink insulation foam cut into 3/4" squares (100's of them) and filled in the area under the floor. Water can run freely under the floor if it wants. When that floor area was still open, I added 2 small drains on the back corners (see the side view nozzle up pic in earlier post above). Pour foam is good as long as it NEVER has a chance to sit and soak in water.
I purchased some sharkthane and mixed a sample then submerged it in water overnight. It didn’t seem to take on any water. Although I’m thinking I’ll run pink foam now.
