I am also putting together an order with mcmaster carr and jetmaniac. If I am missing anything that I should be grabbing let me know.
McMasterCarr
5 packUFO mounts
Adhesive-Mount Nut
316 Stainless Steel, 10-32 Thread Size
98007A024
Pump npt fittings
Brass Barbed Hose Elbow
90 Degree Angle, 1/2" Hose ID, 1/4 NPTF Male End
53525K19
Semi-Clear Soft Tygon PVC Tubing
for Fuels and Lubricants, 3/16" ID, 5/16" OD
5552K24
for Fuels and Lubricants, 1/8" ID, 1/4" OD
5552K23
3 Plastic Quick-Disconnect Tube Coupling for Air and Water
Plug, 1/4 Coupling Size, for 3/8" Barbed Tube ID
5012K72
6 Plastic Quick-Disconnect Tube Coupling for Air and Water
Socket, 1/4 Coupling Size, for 3/8" Barbed Tube ID
5012K68 (three extras for flush kit)
For Fuel x2: Plastic Quick-Disconnect Tube Coupling for Air and Water
Plug with Shut-Off, 1/4 Coupling Size, for 1/4" Barbed Tube ID
5012K85
Socket with Shut-Off, 1/4 Coupling Size, for 1/4" Barbed Tube ID
5012K82
Fuel Safe oring for quick disconnect: Chemical-Resistant Viton® Fluoroelastomer O-Ring
1/16 Fractional Width, Dash Number 011
9464K13
For primer x2: Plastic Quick-Disconnect Tube Coupling for Air and Water
Socket with Shut-Off, 1/8 Coupling Size, for 1/8" Barbed Tube ID
5012K38
Plug with Shut-Off, 1/8 Coupling Size, for 1/8" Barbed Tube ID
5012K44
1/16 Fractional Width, Dash Number 008
9464K13
Temperature-Indicating Labels
Horizontal Orientation, 86 Degree to 140 Degree F
59535K13
JetManiac
Hood side prongs (Stock SS or Cold fusion?)
SS pole bolt
Turf
second hood side catch?
I am think about running two hood latches on the outer flank of the flat section of the hood/dash. I thought it may give me some added security without having to resort to a hood strap. Thoughts? I would need to order a hood side catch, I have the latch.
Thanks
