I did a straight tube but if you have the room in you right gunwale putting an angle or bend may be good. I had a toe hold to contend with. Stock on the square it sort of points up at an angle and cuts through part of the right gunwale, not really a bend in the stock one even.
I have seen people get a 2.5" PCV tube and cut teeth in it, tape it to a hole saw and you got yourself a long hole saw that shouldn't cut through fiberglass, just foam.
It may be a pain to do but I think you can do it without totally gutting your tray. You could also take the opportunity to refoam and totally gut it as well if you like, may be easier than fighting the foam.
Good luck.
Edit: Just read you tray is defoamed, sorry, did not have my coffee yet. Super easy then, just cut bigger holes and slide the tube in. One thing however, if your rear has been chopped and its at an angle like mine you will have to oval the hole since you are not going through the transom at a 90 degree angle.
Good luck.
