RICKTER talk
ThatGuy
NJ
Am i missing something but this looks like a great idea. i can't believe nobody commented on this. Do you want to make more? i cant be the only person that would want one. If you don't can i get a little more instruction on how to make. It looks super clean and strong.
mine went right together as well...granted, the pump shoe was already in it when I recvied the hull...
kawi 750 cable in there as well with a 61x motor, TLR 48 with stock throttle drum
here's a pic of the installed noserail....still ging to pull it back off and run a bead of black 5200 round the nose..
used 1" SS carriage bolts, a 1" washer and nyloc..........put the first bolt about 4.5 inches from the front edge of the turf, then spaced about 5" apart
it feels rock solid like you could pick it up from the rail
and ZERO holes thru the nose!!!!
The rickter is a nice hull. The fit and finish are by far the best out there.
Until you start riding them. :lmao:
J/K.
Take a look at a Lightweight.de hull when you get a chance. Those hulls define the meaning of fit and finish.
Im ordering one of these literally within the next few days..
Does the Fr2 come with a scupper standard ?
Can you run a blowsion dual Bilge bracket from the SJ in one of these?
Yes they come with a scupper installed, coupling spacers to move the motor forward if you want, adjustable motor mount bases, hoodseal, footholds, 2 breather tubes, and a pole bracket, all installed already. I think you can fit the dual bilge bracket but dont really need dual. If you get a newer one they are using a new style hoodseal that is excellent!
Are any of you Rickter guys unhappy with the width of the adjustable foot holds? There's over 2 inches of width you can get the holds in the pocket more. I'm working on a bracket to fix this.
ThatGuy
NJ
Don't forget to give them some height adjustment also. I know there is at least a inch or 2 of room. I will take a pair
