Tons of updates! I have gotten an absolute ton lately. I ground off all of the weird white paint on all the surfaces I was going to glass in the engine bay, blended the ribs a little more, ground down some plexus so I could get the 1708 biax to lay good. Filled the bondline with thickened epoxy along with some chopped strand mat to add some rigidity, then laid a big piece of 1708 biax extended from the bulkhead to the set of 3 ribs in the top deck of the nose. Didn't come out perfect, but came out pretty darn good and has definitely added a lot of strength! While the ski was tipped over, I also laid a piece of 1708 biax on the side of the tray. The next day I did the same on the other side. Yesterday, I put the ski up on a Hefty tractor lift upside down and got to work on grinding the paint off of the handlepole bracket area along with underneath the hood seal area. This thing is gonna be ready to take some killer pancakes.
I laid 3 layers of 1708 biax getting progressivly bigger. One piece that was 9x5, the other 9.5 x 6, and the other 10x8 or something like that. The last piece was big enough to wrap around the hood seal area. There's a bit of excess glass that I'll be grinding off, but it turned out super good. Then I took 4 strips of 10 oz e glass and laid one strip underneath each direction underneath the hood seal area. So 2 33 x 2 inch pieces, and 2 19 inch pieces. Then, I laid a strip of 1708 biax towards underneath the rear of the hood seal to add some more strength. Since I had some excess resin left over, I put a square of biax in two rear corners of the way top deck.
Today, I'm going to flip the ski over and get to work on the tray and the engine bay! Need to do a lot of prep in the engine bay to get off some old adhesive from the tank and waterbox mounts. Might take a little bit to grind it off, but then I'm gonna lay some glass to the areas that got vibrated into, and fix the hole that was rubbed through from the waterbox. Gonna lay 2 layers of 1708 biax in the tray, and then a layer of 8.9 oz e glass over the sides of the tray extending into the bottom of the tray. After that cures, gonna put footholds in, glass in with a couple layers of 8.9 oz e glass, and then put another layer of biax in the tray over them. Should have that done later this week. I accidently ordered 2 x 1 slow hardener, so I have to get some halogen lamps so it cures faster cuz I need to get this done fast.
Also today, I'm going to finish grinding out the hood liner and reinforce the hood and make a repair. While I'm waiting for that, I'm gonna clean up my engine cases and gasket surfaces and get assembling the motor this week. Hoping to start assembling the ski late this week, and then water testing and break in next week.
Yesterday I worked on my ski from 4 pm to 12:30 am, so I'm determined to get this SOB done for the dells! I will get some pics later. It's all going supa good!
