Custom/Hybrid So... What are your off season/winter build plans?!
Roseand
The Weaponizer
Wisconsin
Oh yeah and I gotta finish up reinforcing my sn hood and make a hood liner. Soo much to do!
Yeah Quinc, after school today, I'm getting some work done on it. Getting all inserts and tubes glued in fosho.
Sent from my XT907 using Tapatalk
stagesrt4
see ya out there
St Charles IL
over the weekend we did..... winter builds dont take long enough ha
blaster
-factory pipe
-hooker impeller
-carb rebuild
-rejet carb
X2
-factory pipe
-skat 9/17
-R&D intake
-sbn44
-rejet carb
-zero flywheel
-lanyard S/S
-finger trigger
650sx
-skat 16
-zero flywheel
Quinc
Buy a Superjet
California
SquareNose
  • Shorten 2.5"
  • Cut ride plate to match
  • Reinforce
  • Foamed tray with HD foam
  • Added Toby Footholds
  • Cleaned threads on every bolt hole
  • Blowsion reinforced hood and front nose piece
  • 61x New top end 754cc w/ Freestyle porting
  • New crank
  • New carbon tech reeds
  • Solas prop re-pitched to 13/15
  • ADA girdled head 35cc domes
  • Exhaust manifold port matched, polished and opened up to 46mm
  • Aluminum pump shoe
  • Blue printed pump
  • New pump bearings
  • Aluminum pole -2"
  • New Blowsion pole spring
  • Blowsion 0 degree bars
  • ODI grips
  • UMI Quick turn
  • ATP Freestyle nozzle
  • New 2006 steering cable
  • Deleted stock bilge
  • Dual Rule bilges on separate switches/fuses
  • Dual cooling
  • More crap I cant remember
  • Just need to paint, turf, and put her all together
Blaster
  • Freestyle ported
  • ADA girdled head with 37cc Domes
  • Port matched and polished exhaust
  • New lord mounts for Coffman Rocket exhaust
  • New Solas 14.5/18 impeller
  • Blueprinted pump
Damn this hobby is a black hole of time and money...
Roseand
The Weaponizer
Wisconsin
@Quinc
I listened and did some work today! From 4:30 to 10 pm with no breaks, or eating. Checked to make sure all my thread a were good, got some old adhesive off, did an absolute ton of prep work, drilled and glued and screwed in drain plugs, glued in cooling tube, trim tube, taped the insert holes shut and sealed them with gflex, and since I had a lot of gflex on them I threw a piece of 6 oz cloth over all of the inserts, sealed every thru hull tube and anything that could be sealed, with gflex, glued and riveted exhaust pipe, and all that fun stuff..I'm gonna use some 5200 over some areas just to make sure they're absolutely sealed good. And where the exhaust tube meets the bulkhead I'm gonna use 5200 instead.
That was a lot of tedious work..
Here's a pic:not the best quality pic. Some of the gflex is black cuz I threw some dye into it.
Roseand
The Weaponizer
Wisconsin
BUMP! Time to start planning..
My plans this winter:
Hull-
Remove stock decals-Go with a white theme and black chinpad, black turf, and some awesome x-h2o, jetmaniac, etc. decals.
Shorten it 4 inches, straight cut
Add tom21 sponsons, cut ride plate flush. Possibly shorten my pole some more.
Widen the tray to the turf line, design some foothold plates on a CAD system(Learning solidworks at MSOE right now, might as well put it to use!) and have them cncd/laser cut. Then I'll either make a krash style foothold or straight up buy them, depending on how much time I have.
Add a front foothold
Performance-
Replace small metal exhaust thru hull tube with RN sized tube, also replace waterbox with an A/M one
Sport port cylinders
Port b pipe mani/headpipe
Check timing with a timing light, then advance it a couple degrees.
Lightened flywheel, possibly bored nozzle, etc.
It's definitely gonna rip!!
hhh
my ski is pretty well dialed in now. got a small repair to make. get a perfect @TOBY turf job and probably add a few more colors to my paint job.
biggest project is restoring re doing my new to me truck. always wanted this truck. my dad bought it new when i was 10 and i was instantly in love with this body style.
i was suppose to buy it from him when i was 16, but he was attached and wouldn't let it go. so finally at 31 i got it off him.
second pic is my basic plan for it, with a little different paint job. still mostly white.
hhh
im a frame dragger at heart. always will be. going to keep this mild 2/4 since it will be my daily drive and still have to haul boat and skis.
my s-10 is so low you have to lean it over to get a slim jack under it and its still hard suspension. no bags.
KTM434
Jamie FN Hickey
Palm Coast FL
I had a hitch on my lowered Sonoma that had the drawbar through the license plate area on the roll pan so while driving normal you could not even see it and then while towing you just move the license plate.
KTM434
Jamie FN Hickey
Palm Coast FL
I'm still torn. My winter plans are either get a fresh Aquabot hull or keep the one I have and say screw the off-season to keep riding...
