swapmeet
Brotastic
- Arlington TX
Alright ya'll....
I've tried so many variations of carb tuning, including trying a buddy's carb.
It feels like what I believe is a low end bog. I've used a variety of low jets and low speed screw settings.
I can't even recall but its been everything from a 130 to a 112.5.
None of this has solved the issue, the only result is that if I turn the low screw down too tight with too small a jet it won't idle...
Engine:
701, hammer porting GroupK
Protec head, 155 &160 psi 37 cc domes I think.
MSD (not total loss)
B-pipe
Currently the carb is set up as:
120
147.5
1.5 N&S (i've tried a 2.0)
115 spring (dull silver correct?)
Here are some other items of note, not sure if this matters but lets discuss.
I took some video today. My gopro ran out of batteries, of course, but I got a little video of what its doing,
But maybe you can watch and listen to this and help me out.
Its starts right as I got out of the no wake zone. If you watch my finger and listen/ watch the acceleration, its delayed.
Also, if you keep it pinned it hits like a light switch. Its almost unmanageable how hard the power band hits after it clears what feels like the bog.
It bogged great right as the gopro died. The youtube video cuts it off worse.
Anybody have any suggestions?
*edit* the lag on youtube doesn't help my situation... hopefully you can hear it at the end and understand what i'm talking about.
Engine:
B-pipe
120
147.5
- I'm running two wear rings. It creates a larger cavity of water before the prop, pushes the nozzle and prop 3" farther back.
- Scat 11/17 swirl prop, no cut back
