i like 25mm on the bottom and top , more cushin for the pushin , superlockdownohmygodican'tgetmyfeetoutoftheholds.
lol!
Some observations from my build:
- Double-check all your bolt lengths. Many inserts are shorter than stock to allow for the super-low profile of the ski. You don't want to break stuff with bolts that are too long.
- If you are getting the integrated front foothold, the standard coupler cover will not fit. You need to cut it in half lengthwise and perhaps grind some material off the top.
- Don't put the ebox over too far to the pipe side. The ebox cap will interfere with the head pipe.
- The hull sides are so thin that a standard bilge fitting will have the nut bottom out before the fitting is snug. Use an o-ring or a washer behind the nut from the bilge side.
- When you glue in the hood seal, be sure that the front-most portion is as far back as possible.
- Make sure your hood side hood hooks are on the right way and not flipped 180 degrees.
- You can most definetely fit two 500GPH bilge pumps by the midshaft.
- Lock-tite your trim & steering nozzle bolts.
- Hang the
on. This hull is ridiculous.
Heh, I actually run a stock syphon.
I like 25mm on the bottom and top , more cushin for the pushin , superlockdownohmygodIcan'tgetmyfeetoutoftheholds.
Has anyone used the watcon hood seal on their superfreak? I bought one because I love it on my superjet. I'm a little worried it might be too tall, but didn't want to use the stock hood seal because I don't think it lines up very well the way the hood sits. Thoughts?
I might just have to wait until I put on my brap strap and crank it down.
I'm running the Watcon seal. I put it in last year and it's still working fine. I ended up slotting it to let the hood lip seat better. I've had no water intrusion issues yet.
