Nice build, I've never seen somebody keep a ski foam-less! Definetly has its perks, but if you get a leak, or your ski is hit and is sinking..... There's no foam to hold it up. If I were you, before glassing get some polystyrene extruded foam and cut some chunks up and stuff em in there.. Foam is also to reinforce the tray, it helps with the structure and durability. I'm surprised the tray isn't cracked at all!
Most WDK hulls are foamed but you are right, there are a lot of hulls that have no foam. Kwakhead is new around here, he just acts like he knows everything.Superfreaks are foam less......I think most waterdawg skis are too. It's happened probably a lot more than you know.
Most WDK hulls are foamed but you are right, there are a lot of hulls that have no foam. Kwakhead is new around here, he just acts like he knows everything.![]()
Swap the drain plugs for versiplugs, I had refoamed a hull with polystyrene and found myself draining it every time I came in as well. I swapped in a couple versiplugs and it made a noticeable difference. Will you be able to continue to use the stock gas tank with that much nose rocker?Right now, my plan is to foam the tray.
As it was, the tray leaked a lot, but that's why the ski had drain plugs installed. I'd empty the tray while filling up with fuel (had to fill up often with the small kart tank). I could also feel the tray flex quite often, which had me concerned at times.
Thanks for the advice, versiplugs are part of the plan. As for the fuel tank.... I need to test fit a stock one before buying. I'm not 100% sure if it'll fit, but I'm not too concerned (I'm okay with the kart tank).Swap the drain plugs for versiplugs, I had refoamed a hull with polystyrene and found myself draining it every time I came in as well. I swapped in a couple versiplugs and it made a noticeable difference. Will you be able to continue to use the stock gas tank with that much nose rocker?
At least I'm not a nube lolMost WDK hulls are foamed but you are right, there are a lot of hulls that have no foam. Kwakhead is new around here, he just acts like he knows everything.![]()
It's how West System describes it... Tons of good info on their site: http://www.westsystem.com/ss/fillers-and-additives/What made you decide on that "catsup" mixture?
Agreed!Looks good man, we gotta meet up this summer for a ride, been almost 2 years!!
