Custom/Hybrid Surfjetlouie memorial build
snowxr
V watch your daughters V
Waterford, MI
Fellow board member SurfjetLouie lost his fight with cancer on Thanksgiving day 2008.
I'm asking for help to preserve his memory, and do something nice to help his family with a college fund for his daughter. I'm hoping to get in touch with his family soon to set it up.
I'm donating a RN cnversion topdeck to start a build which will start shortly after the Daytona Freeride. Madscientist has already donated a SN hull for the conversion.
Now I'm asking everyone out there that would like to help to donate parts or a small amount of money to aid in the build.
My initial idea is to have a raffle at a freeride. I'm open to suggestions.
On the boat will be the names of all who contribute.
Now the work begins. I'll start a list of parts needed, and find a way to collect donations this week. Lets make this a great build to honor the memory of Louie.
Thanks everyone
Kurt
RoyalFlush@PCB
Shootin' The Crap
PCB
I've got the hull that madscientist is donating at my house. I'll look around after you post your list and see what I might be able to donate.
Thanks for doing this for Louie's family! :fing02:
RIP Louie.
RIP Louie. Dam. This is terrible.
I'll post up a list of parts i can donate after i dig through my bins tonight. i think i have quite a few pump parts at least.
snowxr
Waterford, MI
Here's a list of parts needed. I'll do my best to edit the list as parts are accounted for.
Topdeck conversion Snowxr
Donor hull Madscientist ACCOUNTED FOR?
DASA/Lamey Cylinder Dasa/Lamey ACCOUNTED FOR
Crankshaft SBT RECIEVED
cylinder head Yamasaki RECIEVED
62T cases PURCHASED
B-pipe NEEDED
reed cages Yamanube RECIEVED
hood NEEDED
nose piece SFL RECIEVED
pole mount Danceswithsuperjet RECIEVED
hood seal The Penguin RECIEVED
ride plate X2 RAGS RECIEVED
handlepole NEEDED
steering NEEDED
bars Jetskihaven RECIEVED
pole spring Danceswithsuperjet
pole bolt NEEDED
hood hooks NEEDED
hood latch NEEDED
fuel selector big kahuna/ snowxr
primer kit jetskihaven RECIEVED
pump jetskihaven RECIEVED, but need driveshaft
prop (any stainless prop. this can be sent to impros fo repair/repitch) NEEDED
reduction nozzle Jetskihaven RECIEVED
steering nozzle NEEDED
bow eye qty. 1 from Danceswithsuperjet. 1 from jetskihaven RECIEVED
fuel tank NEEDED
fuel pickup Mike W RECIEVED
gas cap with base Big Kahuna/ SnowXr
handgrips Danceswithsuperjet RECIEVED
start/stop switch NEEDED
throttle lever SFL Surfrider RECIEVED
throttle cable Big Kahuna
steering cable NEEDED
motor mounts NEEDED
engine bedplates SFL RECIEVED
midshaft NEEDED
couplers 1 from Mike W. 1 jetskihaven RECIEVED
damper- Mike W RECIEVED
driveshaft NEEDED
battery box SXIpro RECIEVED
flywheel NEEDED
stator SFL Surfrider RECIEVED
cdi Freestylegeek 61x RECIEVED
e-box parts Jetskihaven RECIEVED
pole pad NEEDED
carbs NEEDED
air cleaner adapters 44mm Jetskihaven RECIEVED
intake stk 38mm Jetskihaven RECIEVED
misc. hardware
We'll need some $$ for supplies, like paint, sandpaper, turf, etc. If people would like to send spare parts that we can e-bay to fund other needed parts we'll do that.
contributions can be sent to my paypal SnowXr@aol.com
Current budget as of 12-14 contributions $55by: Pancakepete, XFT Lou
Thanks for the help.
Kurt
madscientist
chilling with these guys.
good old p'cola
hey mark what parts are already w/ the hull? answer your phone!!!!!!!!!!!!!
thanks for the support guys. i have been wanting to have a reason to help someone out
i have a mold for the nose peice, i can make 1 if nobody has 1 to donate
Mike W
Infidel
North Florida
I will donate the rest of the epoxy resin (uscomposites) which should be plenty for footholds and some other small stuff. I also have about 3/4 of a quart of 3lb foam left I will donate as well.
As far as parts I have:
-fuel pickup
-intermediate shaft rubber biscuit
-SN side bumpers (if needed)
-I have misc bolts. I should have what you need. LMK
I'm sure I have more but I will have to look.
*Just a suggestion. This build should have Louies footholds and Tubbies. That would be fitting.
snowxr
Waterford, MI
Great guys. Thanks.
Madscientist, If you'd like to do a nose that would be great. If we don't cme up with a lowered hood I could cut a stocker, or we can sell the nose to buy another part.
Mike W, thanks for the items. We can use everything except the bumpers.
Danceswithsuperjet, we're doing a RN conversion. The pole bracket and spring would be great.
Thanks again.
BTW my address is
Kurt Jones
3855 Hazelett
Waterford, MI 48328
Feel free to ship items at your leisure.
Mike W
Infidel
North Florida
Great guys. Thanks.
Thanks again.
BTW my address is
Kurt Jones
3855 Hazelett
Waterford, MI 48328
I will ship everything in a week or so. I might find something else to throw in.
madscientist
good old p'cola
mike you can send that to me for the nose peice. i may just make it out of carbon since i have a bunch here
Kurt,
I have a stock hood that has never been used off of a 97 superjet located in Spring Lake, Michigan (Grand Rapids area) if you want to pick it up.
I also have a few misc parts such as electronics, misc cables, and stock steering.
I also have a prop I could donate that is in pretty good shape. I have another that I could send to Dave at impros, and then have him forward it on to you. I am sure he would clean it up for free. Both props were pushed by my Lamey 780CC, so it might not be applicable to your build. Just let me know.
TB
NOTHING IS EVER PROMISED
Grand Rapids, MI
so is this build going to take place in mi? if so i'll keep the title here with me since i'm ack now and might even be able to donate a weekend of time into helping to put it together if you got a couch
SN
-OEM Pole braket I think almost complete no spring
-650 CDI unit
-Flywheel
-Back end of E box
-Misc parts,odds and ends
Let me know what you want need ??
snowxr
Waterford, MI
Things are really coming together quickly! Just to clarify this is a RN conversion deck going on the SN lower hull. We can used lots of SN parts, but pole and hood will need to be RN parts. I see a hood or two being offered, so we'll see what works best.
I see a lot of useful parts being offered up. Thanks everyone.
Thongbandit, thanks for the offer. I'm 45min north of Detroit.
