- grand island ny
i have xmetal setup i made my own clamp setup with down hill mt bars 1 1/8 .7.50 for 2x2x4 block of aluminum 20 bucks to get it drilled and cut well never go back to straight bars again
i dont like them, riding them i notice i cant get my hand down as low as i normally do so that messes with my balance. something that can get used to i guess, but why?other than that, they felt exactly the same as stantard bars. the worst part is climbing up on the ski with them. they make it so akward reaching up to climb aboard. stupid.
will these bars make you a better rider?
no.
I figured I would bump this thread to see what everyones opinions were on these bars since I need new ones. Does anyone know if riser bars will work with WDK steering
I hate riser bars...like, really hate them, that is all.
which umi runout bars did you use?
How wide are they?
Bringing this one back up again.
I'm seriously considering going to a riser system on my SXR with UMI pole.
My problem is that I really don't like 0* bars that much (so RRP and Blowsion Kommand bars are out), I'd like to find some that have some sort of sweep. So, I have a few options.
One would be some runabout/mx bars. Issues with these are they are manufactured to use the cross bar for strength. 7/8" Renthal bars specifically say not to remove the cross bar. I haven't looked for such info for all manufacturers, but I'm going to assume removal of said bar is not recommended. The great thing about running runabout/mx bars would be not having to buy a 1 1/8" adapter.
The other option would be to go with a tapered bar setup like these Renthal fatbars with no cross bar (or Pro Tapers). Of course I'd have to buy the adapter.
The last option would be some bicycle bars, not sure that I like that, but much cheaper (for the most part)
The one thing I'm not sure about, fatbars all seem to have a rise to the grip area, not just sweep (in addition to the initial rise after the mounting point). I'm not sure if that would be a desirable feature or not as far as comfort goes. The one bonus I see about this feature is that it will basically be aiming your throttle and trim cables back toward the plate for a more gradual bend.
The fatbars I'm looking at in particular are the Renthal 672-01 bars. They have a rise of 55mm, but a total height of 80mm plus a pullback of 57mm. They are 31.3" wide, but I'm sure I could cut them down some if I don't like them. Or, on the Pro Taper site the Pastrana MX has a rise of 54mm and a total height of 74mm, so a bit less than the Renthals with basically same width and sweep. The Pro Tapers are actually a bit less money, but $70 is still not something I'm wanting to just 'tryout' and see how I like it.
