the trivial complaints thread
Installed a used torrent 148 in the reaper. New skat impeller and new bearings. Spent at least an hour getting the drive shaft lined up perfectly. Gave the engine a once over, cleaned the carbs put the wax v3 timing curve on the zeel. She starts right up runs for about 10 seconds and she dies with an awful sound.. Pulled the tank back out and check the flywheel thinking the bendix or starter got stuck (also installed new brass bushings) Ended up being my pump is froze! Not sure if its the impeller stuck or the bearings yet.. I pulled the pump out, could not get it to budge with a wrench, said f it, and started drinking... Odd thing is I was able to spin it no problem by hand before installing her. Was a little tight but figured that was the new seals..
Who made the driveshaft?
OCD Solutions
Rentz, GA
Would you buy anything from this guy?
Plano, TX
I hate it when you go to get something out of your toolbox and it’s not there. Trying to get my ski together and my dang driveshaft holder is mia. My hd Prop tool is where it’s supposed to be and the wrench for it. Can’t use one without the other. I tore my garage apart last night looking.
Tuscaloosa, AL
I did that last summer looking for my cold fusion flywheel lock......... Looked for over an hour. Looked for that damn Black Anodized Effing Tool forever and could not find it........... It was right in front of me the whole time on my counter............ It is Red................
OCD Solutions
Rentz, GA
I spent my entire weekend looking for a $20 bill. And I never did find it so you know my OCD is going crazy!!!
I stuffed it in my left front pocket Friday night and have not seen it since.
