- Central Florida
How does this mount in hull? Exhaust angle indicates upright. Adapter kit? I always had clearance issues with the bottom bolt on flywheel cover hitting bottom of sj hull. I would love to know more about the xscream crank. Nice work, bolting on existing exhaust systems is huge
i took that bottom bolt right off your old motor, and had to change some case bolts, only have about 3mm of clearance in one spot
this will be one angry motor syked to see some videos however just a thought ... if the x scream 1200 uses a stroker crank with a 94mm top end and the waterdawgs 1200 uses a stock stroke crank with 99mm pistons would it be possible to combine the two i.e the xmetal stroker crank with the wdk 99mm top end and produce a crazy 1300cc monster ????i think someone with the equiptment should consider looking into it.
i plan on installing a billet crank in my 1200, it will loose 4.5lbs off the crank. that will help it to rev more like the xscream motor for sure. would be interesting to compare the 2
bump for an update
