TNT v2 free ride production pipe
Plano, TX
You could always run the RRP or PFP box if you can't fit the TNT. The box is def large, it fits my freak fine with the thrust tank though. Just mocking up so don't mind the mess of clamps and what not.
Is that the thrust 5 or 4 gallon tank in your freak?
PNW
TNT chamber first ride report
Let me start this by saying I had a very tuned setup by @Aquaholic with my PFP (setup wet) Everything was dialed in and the boat ripped on bottom and mid, but seemed to go flat on top. Everything was working in harmony, so it was a leap of faith to try something new and hope for improvement.
We switched out the PFP chamber for the TNT last night at the Braap Dr's garage, and didn't touch any tuning settings. My ski is now spinning the prop a little on the low/mid and it's hitting much higher RPM's than before. This is going to take some riding and foothold adjustment to get use to the added power, and we haven't even started tuning it yet!
It's nice to buy a product that lives up to the claims...
My setup: Dasa 918 5mm, Dasa 48's, MSD TL, Skat 148 setback mag pump. Edit, PFP water box.
tntsuperjet
Georgetown ca
If you want to polish the pipe you best to use a alumabrite or etching mag wheel cleaner.
Spray that on all the welds and use a soft bristle brush do welds couple times. That will take all the color and slag off the welds and it polishes much faster
Uk
Got my pipe, cheers Tim and Brian :)
Did as Tim suggested, washed off with paint brush and alloy wheel cleaner then a quick rub by hand with metal polish.
Looks awesome.
mike b
California
Looks awesome.
Any pictures installed? The normal look is wicked in these hulls but that polished pipe looks great
mike b
California
I hope to bring a couple v3 to Daytona for display
But the official release date is feb 1st
How much for chamber and how much for complete kit? Are they available in a full kit? Hoses, manifold, etc? When will just manifolds be available?
mike b
California
Feb 1st they will be available in a kit.
Retail will be 1495.00 for the full kit
Manifold to water box
Couplers and all? Foam blocks? Sounds like long hose will be needed from water box out the rear?
