I don't know why the return is drilled out . . . seems it would be to lower the pressure in this particular case. If the pressure was lower, would that effictively change pop off? I mean the pop off would be the same, but the pressure necessary to pop it off would come later.
I'd like to know more about how all of this works, but I don't even know who to ask. When I get on the phone with an engine builder I don't want to waste their time so I don't always ask all the questions I want to.
When I spoke with Chuckie on the phone and took down my notes on this set-up he explained that "newer, high-performance" engines were using fuel injection, and that these were intended to simulate that to one degree or another. The doubled fingernail valves are intended to move more fuel through the lower circuit, or to wait to "turn on" the upper circuit.
I'm not necessarily dedicated to any one source . . . I just want something that hits, . . . and I want to ride. So R&D is fine in small doses, but I want to spend some time ripping it up as well. Plus I'm usually out there doing this by my self, and I feel less than competent, so I don't fiddle too long. I don't see the point because I don't have any "why" behind what I'm doing.
I need to go through this, in person, with someone that knows what's up and then I'll never forget. Until then I'll fumble my forward.
