wildman326
Who else?
- Kansas
Oh. Yeah. That could be a big problem. I haven't had a primer in a long time. Do you need it often?
S&Ssuperjets said:Matt I have the same setup as you what intake are you useing ? I'm useing the 64x intake .. Is that what you have ? can't wait to see the end result..
Matt_E said:Here are today's observations:
I took it out with the following:
2.0/95g at 25psi (measured...it's NOT 24, but 25)
115 Pilots 1-1/4
110 Mains 1-1/2
Doubled up checkvalves
It runs too rich. The bottom end is almost there, but still a bit too rich.
The top end is most definetely waaaay too rich.
I still didn't receive my jetting in the mail.![]()
If it doesn't get here before the next time I go out, I will try to compensate for the slightly rich off idle condition by sticking 115g springs in there to raise the popoff.
ALso, I got 105 mains I'll stick in there.
Oh yeah, the primer is completely disconnected now.
