wildman326
Who else?
- Kansas
My motor is cut to 55mm at waist of exhaust, cleaned up intake & boost ports, sleeve sides raised 13mm, race finish, cases filled and fingerported.
Re-cap:
2.3 NS
65 gm spring
doubled up fingernail valves
112.5 pilot
102.5 main
drilled out return to 3/32 or so (not critical)
70 main jet in return line (after T)
1.25 turns out on bottom
1 turn out on top
and
stock flame arrestors
stock intake filled in on sides and bottom to match reed stuffers in
carbon tech reeds on Kawi cages
1/4 inch intake spacer to compensate for longer reeds
I don't know if I mentioned this before or not, but my carbs don't dribble at idle. They don't load up. There is no hesitation that I have found.
I think that a stock or aftermarket intake (with non kawi reeds) would work equally well and intend to try it later in the season. I'm going to take another stock intake and fill it in for v-force reeds. I personally prefer the stock intake. It's nice to have the carbs linked when you take them off, plus they're cheap. I'd probably use the Brazina intake if I had more $$ and less desire to tinker.
Re-cap:
2.3 NS
65 gm spring
112.5 pilot
102.5 main
1 turn out on top
and
