- So. IL
OK folks, that is what a piston and cylinder look like from the effects of Detonation. the ring colapsing and and catching the port was a side effect (in this case) as a hole was burned thru the piston,
this motor failed in my opinion from detonation, could have been lean on the carbs, air leak , too low an octane fuel, old fuel ect.
Db
That is exactly what I was going to say. I have a few snagged ring pistons at the garage that I kept and none of them are melted. plus that "pin" that you call it stuck in the piston is HUGE compared to the pins that I have seen. What about if the guide pin came out and then the ring spun around and cought the exhaust port is that his fault. Or are you going after Wiseco. Trust me Wiseco won't pay for it. I tried and if there is ANY piston to wall scoring it is not there fault.
I still side with Wydopen he owes you nothing. I wouldn't pay a dime especially since the pictures are up.
