I think you have to have pretty deep pockets to play that game, and long arms too. My buddy keeps telling me I need to develop one but there's not a chance in hell I want my pockets or arms anywhere near something like that. I have read your posts and in between the lines of your comments for years now and gathered it was not nearly as simple as it sounds.
I'm conflicted on the whole warranty expectation from ATP though. The one Epic in our group gave our buddy absolute fits and cost him a few thousand dollars all said and done. But, that same unit worked flawlessly in every other ski we swapped it into. Sadly it was destroyed, (battery hooked up backwards) before we could get to any resolution on it. So, from our experience, the issue was with the ski electronics themselves and not directly the EPIC. It's sad for my buddy but how do you claim a unit faulty and demand a warranty when it still works in 4 out of 5 skis? I have always maintained that it was a lack of RF shielding or filtering in the power circuit that made it extra sensitive to electrical "noise" but that's hardly any consolation. If nothing else, it would have been nice to find an external filter or some other fix so that the original version wasn't a total write off.
The good news is, the Gen1 EPIC happens to run flawlessly in my ski and spares are getting cheaper and cheaper!![]()
I think if everyone here was willing to tell their full story on the epic and hx3 and there were no relationships involved it would be a total diff story and save alot of ignition newbs mega headaches.
I understand this forum no longer welcomes Industry professionals or
@Quinc, You have a 4-5 year old Epic you bought used, not HX3. YOU DID NOT ASK FOR A DISCOUNT ON A NEW UNIT, NOR DID YOU ASK TO SEND YOURS BACK, Why come on here and lie????
Next time you need forum fuel, go elsewhere.
This place likes facts.I understand this forum no longer welcomes Industry professionals or facts but...
@Roseand, You must be deluded to think your Epic works well, get with the cool kids ie Wax etc. This forum won't be happy till you conform
@Vortex, You emailed asking for advice, We gave it and you try to humiliate us on a public forum for no reasonNext time you need help I'm sure you will get it from the cool kids on here.
Anybody genuinely needing help and advice, be assured it will always be freely available.
To clarify this whole situation with me an qjc: I asked if there was an update available
title: atp epic no spark when pressing start
Hello I ride with one of your beta testers here in the US. Is there a reflash/update available to address this issue on the earlier model epix units? Performance is great otherwise. Thanks for any help.
reply:
This doesn't sound like an epic problem, more like a problem with your start circuitry. Can you check the battery voltage while the engine is cranking for me? Let me know what you read
On my first ride on this ignition I ran into this issue. Took the ebox back apart, found nothing wrong, put it back together and it worked. It ran well until my stock 701 ate a reed. I bought another engine that is a ported 718 with 215psi compression. My stator is one year old and I have a brand new agm battery. The ignition works amazingly well once it fires up. However, after you ride hard for a few minutes and stop, the ski will not spark again when you press start. The ski is not cranking over slow or showing any signs of a bad battery/connection. It should be firing. If I put the battery on a trickle charge overnight it fires right up.
I read somewhere that the epic resets itself if there is enough of a voltage drop during cranking (why???). Nothing I have found suggests that I have enough of a volt drop to have this issue. I will check again with my meter.
I have a feeling that the ignition is just too sensitive to amp draw. This may not be a problem when you are riding 2 minute flat water routines, but in the ocean or on a buoy course all components are being worked hard. It seems like if you've got high compression, stroker engine, a lot of intial/start timing, the amp draw is perhaps causing the epic to act this way.
He said it didn't sound like an epic issue, asked you to check something for him, your response states that you have a brand new battery, but never a voltage while cranking. I get to diagnose issues all day long, but if there are details missed... specially keys ones like voltage while starting, you can't blame them for not helping.
This actually seems like a real possibility. I never had any trouble but I don't do long riding sessions. Most who have had issues seem to be surf riders. Hmm.vortex.. we had a couple of them that did the same thing years back,tried swapping other new elecs with epic,made no diff. "being speculative here" It was some sort of heat issue in the cdi,sometimes spark would come back sometimes it wouldnt. just unnecessary headache. we just went back to enhancers,but next time it happens try opening ebox and cooling it down quicker with fan and see if you get spark back.The potting cant dissipate the heat fast enough
Wonder how many guys that have had better luck with them are riding flatwater with a small tank short duration rides and never get them very hot.We were riding surf for 2 hours a stretch regularly
I understand that. I asked if there were any updates available. At no point did I hint at blaming atp, I just thought it was kind of odd for them to start off with "its probably not our problem"
It's not battery voltage. If it spins your ski over that's draining more than the ignition. Sure that may stop it from starting as the electronics will have a cut out voltage. But if it happens when it's runnung and the ski cranks gone after that. You couldn't really blame the battery.
Sure, if i dies while running. But vortex had a no start issue. But at one point he says that when he hooks it up to the charger and lets it charge it will then spark and run. That's why I said something about battery voltage.
