So you cant see the diff between a mod and lim chamber on your dynos load and calculation chart?
You make a very valid point with some of those statements about fp and popular opinion here."The prob is hype alone" and no dyno facts..people repeating misinformation they have from mixed sources.and zero facts to back it up. To answer why that opinion has happened here... First we know that race boats are ported high,exh duration over 200 with high transfer timing.They want to turn more rpms up top so they run a mod pipe to do so,shorter diffuser pipe,shorter wave return,running them hotter up top does just that = more rpm. most using elec water inj before top screw,that cuts off then opening the bottom screw to obtain high rpms and keep pipe from over heating and crazy compression,pipe pressures and race fuel and tl ign with high timing,to get them hitting hard down low for a sub 800cc race spec motor
Now a freestyle guy gets passed about half this info but remembers someone said a mod pipe hits harder cause its made for more mods,and if you open bottom screw youll get more "hit". Then they try to run a mod chamber with bottom screw open with a msd enhanser,44 carbs,185 psi ada head,"Lightly"ported low duration 701 cylinder,on pump gas cause most dont wana deal with race fuel here. they never know it sucks until they ride a 701 setup right
Et also found a lim chamber made sig more power than the older tnt for freeride aps as well,although it was a replica,guys were talking it up also.
A water injected pipe thats sprayin water constant through 2 jets to control pressure per rpm,in the water is going to spray the same amount of water on the dyno if the pressure is set similar, all freestyle skis rev fast in water dry piped or wet piped,Some are still getting usable dyno info,for engines,parts,pipes. If we had stickied dyno chart,setup threads here that got as much attention as staff infraction threads,that misinformation would go away quickly. unfortunately we just arent there yet...... For now we settle for..hey this rips harder than others...and wonder why so much misinformation still exists
