XI
I actually really like the way the visual on the hull looks and I think the turf looks great with it. Really a great idea and makes sense for repairs or fixing worn sections of turf.
This is really impressive stuff Mike, thanks for sharing!!!
Thanks! It was an epiphany moment coming up with the turf scheme. My other thoughts were running the waffle diagonally as mini diamonds or just using smooth.
Enough of this fitting of the Bun motor. Time for some control. Handlepole control that is. When I sourced the titanium for the exhaust and cooling lines I also sourced some Ti plate that I used to make these. Titanium pole brackets and titanium backing plates.
DSC03789.JPGDSC03790.JPGDSC03791.JPGDSC06716.JPGDSC06718.JPGDSC06719.JPGDSC06720.JPGDSC06721.JPGDSC06723.JPGDSC06724.JPG
I also sourced some CWSR , (Cold Worked Stress Relieved) .037 2.5 " Titanium for the Aura pole. It just eeks out a win at a tenth of a gram lighter per inch.
Made a stainless safety rod just in case those aluminum pole ends can't grip that polished Ti. And you can still get an Allen on the bolts for torque check.
IMG_3230.JPGIMG_3231.JPGIMG_3232.JPGIMG_3235.JPGIMG_3236.JPGIMG_3237.JPGIMG_3238.JPGIMG_3239.JPGIMG_3242.JPGIMG_3243.JPG
