- Tuscaloosa, AL
I use to have that same multi color HOT sticker on the back windshield of my S10 Blazer!!!!!!!!!
I had the same issue in my 61X intake. Use 1211 on the gaskets not the Yamabond.
Also when running a pipe it is a really good idea to run a girdled head to prevent cylinder cracks.
Pretty hideous isn’t it? I don’t know what to do. Should I just tape up the ports and spray the main parts? I guess I should have blasted the parts before I sent them to Klemm but for some reason I thought they would come back cleaner... Originally I was trying to have this ski finished before the 2020 Daytona freeride so I was rushing a little.Please tell me you plan to paint the cylinder and cases?
Just do like Yamaha did. Mask off the carb opening and the exhaust ports and spray paint everything else.
I forgot to mention also, this is the 760 hammer kit from Group K so I cannot run a girdled head kit according to Harry. The head is actually a modified 62T cylinder headJust do like Yamaha did. Mask off the carb opening and the exhaust ports and spray paint everything else.
And you said the engine isn't really that powerful. You are a liar sir.I forgot to mention also, this is the 760 hammer kit from Group K so I cannot run a girdled head kit according to Harry. The head is actually a modified 62T cylinder head
On bare surfaces and the cases absolutely on the Yamabond. His was leaking on the intake gaskets and 1211 is better for that.I think it depends on the strength of Yamabond, I use 4 and he’s worked fine.
Wait, what? Did I misread something... I have 2 girdled head kits sitting in a box here...And you said the engine isn't really that powerful. You are a liar sir.
I would call Harry as he specifically states that, "Failing to use this half girdle greatly increases the risk of fracturing the cylinder casting around the inlet side base bolts." I know he started making them when Pro-Tec quit.
So........ are you running both girdled heads at the same time or the Group K 62T??????
I would believe Harry on everything he says. He has been my go to machine shop for over 25 years now and never once had an issue. I would call him and ask about the half girdle though. Would be a shame to go to all this work and crack a cylinder.
