2008 super jet release date 8/20/07 12pm EST
W
wydopen
Guest
It would deffenitly be aimed toward racers, not freestyle..... I would still like to see it/ ride it,
im sure we will see something like that soon...im sure they didnt redesign a hull to only use for two years or whatever
Crab
thanks darin...noswad!
Seattle
I assume it uses a longer driveshaft for the setback, I see some pump relocations coming soon. I wonder if they shortened the pole so they could use existing cables also, just a bonus.
more uhhhh photoshop.....
SeaLion
Jet Ski Junkie
Rush,
The impeller is still aluminum. That I will never understand. The pump liner is stainless steel not the impeller.
waxhead
wannabe backflipper
gold coast
i bet it uses the blaster shaft to set it back
when you look up the pump you can see a big hub prop in there
i am guessing its a swirl
Marshj
DarkHorse
Ann Arbor
the impellor is stainless. Period. its a swirl. Look at the pics of the underside of the hull on yamis website. you can see it.
cookerq62
Life's Been Good
Upper Bucks, PA
I called a dealer and they said after labor day they will have all the info. I don't know if thats when you can order one but as of now all they have is a brochure.
