- sunbury ,ohio
how about we get 3ea. 2 x 12 boards 10ft long and reinforce the backs of the boards w/ a 2 x 6 turned at 108 degrees then chamfer the ends to the proper angle and roll w/ it. it's simple to add some grip tape and so on. two of them can be for the tires and one to walk on.
If you use 2x12 by 12' lumber and some 2x bridging to box the three 12's together you could easily drill and lagbolt the current expanded steel to the top of the 2x12's then add a piece of plywood where the current short expanded steel falls short , screw some furring strips to the plywood for gripping ....longer lumber would be better due to the fact that the sand slopes away from the seawall the farther out ya get , but I think 12 'ft is not overkill on length ... then disassemble and take the wood back home / build+cut at home- assemble on site ... any frameing carpenters on board ?? ....... just an Idea
