DIY Total loss or MSD TL upgrade box 270USD?
waxhead
wannabe backflipper
gold coast
Hey can anyone out there in Zeel land please put a multimeter on their battery and see what they are charging at. My battery went flat last time and I am a charging system. I put a whole new front cover etc and regulator but i dont seem to be puming out many volts into the battery
Cheers
Quinc
Buy a Superjet
California
Cheers
I have the same problem. I have the older model Zeel.
I don't remember the numbers but I also have checked and was surprised how close running was to non running. I was expecting something like 13.5 volts running and checked three voltage regulators before realizing what I was seeing was normal. Some fraction of a volt increase when running as I recall, these things have pretty wimpy charging systems.
Stockton
Tested a 62t and it was only (point .2 ) volts more while running on the work stand, quick tested....
My suggestion is test your charging over time with ski in water, do a bunch of starting to draw the battery down. Keep monitoring at different rpms....
waxhead
wannabe backflipper
gold coast
I was expecting 13 -13.5 volts. Ski wasn’t charging and the battery went flat. So had a look and saw a dodgy wire on the reg. Thought when I checked it after that it wasn’t charging still. Maybe it is now and it’s just never much
