waxhead
wannabe backflipper
- gold coast
I can answer here.
I use a dial indicator in the spark plug to measure tdc. I then calculate the degrees of piston movement for 10 degrees and also 20.
From there i rotate the engine until i see the same on the dial indicator and mark a mark on the coupler
So one mark for tdc, ten degrees and twenty degrees.
I then put a 10 degree straight line in the ignition and crank the engine on the starter and using a timing light i check to see where it is.
From there its a simple case of adjusting the static angle until ten degrees in the ignition is 10 degrees on the crank with the timing light.
I then do the same for the 20 degree just to check my work.
From then its a case of running the engine and watching the rpm come up and checking your work. You will find that the a battery driven timing light will not keep up with the high rpm and the ones that are fired of the spark plug only are your only option.
They are not bright but they are cheap. Im looking for deviation in the curve and if i do get it then I put in a correction factor
I have been runing them like this for years. Well to be fair only 5 years on the zeeltronic but I have been doing it like this on other ignitions for the last 10-12 years.
Can you think of a better way and if so please explain it to us, as I am always keen to learn new stuff
