The topic says MSD TL upgrade box
So the 2 options im looking at is:
1. a ZEELTRONIC box to directly replace the MSD digital multi channel brain ( use your MSD pickups, pickup plate, flywheel and ignition coils)
2. a ZEELTRONIC box that will work with 62t (maybe also 61x) superjet OEM ignition (with pulse coil inside flywheel) Making a charging programable CDI (also possible to change to total loss)
@waxhead discovered this with a ZEELTRONIC box to work like option 2, with the 760 ignition setup.
But yes. there is a complete system from CPI, that uses a ZEELTRONIC box, but the pricetag is still 1600usd for complete system - wich i think is a alot, considering the heart of the igniiotn (ZEELTRONIC box) cost 230 euro directly from ZEELTRONIC.
