waxhead
wannabe backflipper
- gold coast
Why not just use a 760 front cover like we areMight as well just sell the msd stuff and get a legit jstl set up
That's what I would do/did but he seems set on trying to adapted with an msd. Wich seems like more trouble than it's worthWhy not just use a 760 front cover like we are
And by the way, the only part the JSTL produce "them self" is Flywheel made by ET and pickup plate, guessing also ET.
Hallsensor, coils and brains are sourced from other companies![]()
A couple things to remember about these boxes. The max timing advance is linked to your static timing. If you set static to say 30 you cannot advance more than 30 no matter the curve advance. Second if the static angle is set to high as in incorrect, the advance curve will be less than programmed and visa versa . I would like to know how you varified that 54 degree number as static timing ? That number should have been the trigger point after tdc. As per Zeels tech the advance becomes too unstable after 45 degrees. They rec less if at all possible. I've tried this myself and can deff see the timing becoming unstable. The time delay will help at lower numbers stabilize this
Have you run one of these yet? Angle is 56 if I remember correctly. Runs smooth and stable per Wax curve at least with a few people going years on these boxes with zero issues. We run 0 degree static and advance through software.
That's what I thought
anyone see a problem with me running 760 flywheel and stator/cover with my 61x e box and associated parts i would need to re use? i want to ditch the charging setup, will the zeel cdi fit in the oem box? thanks
Also I'm not understanding why static timing for the zeeltronic would vary for different stroke motors. Isn't it just the angle in crankshaft revolution between the trigger point and tdc? How would that change with a different stroke crank?
Anything having to do with the relationship between piston travel and crank angle would change, but this parameter depends only on crank angle.
Because of the dwell at tdcIt's not a lot of difference. Only 10ths in millimeters
