Quinc
Buy a Superjet
- California
which one do we need for the kawasaki zxi1100 pwc?Questions about Zeeltronic ignitions? We import and stock them here: https://www.fastfromthepast.com/ignitions
Jim Hinshaw - Fast from the Past
Do you have wire diagram for your setup? My MSD TL box is bad can I just use this Zee to run my TL System?i have a twin coils set up total loss Zee set up , on of the last that art (ET)was able to help make with California Freestyle. its the equivalent to the MSD total loss but easier to change the timing curve ( just plug in the hand held unit and change the points simple ) you get like 20 points compared to the MSD 5 point and don't have to pull the unit to flip switches. i run it on my Revolver with a dasa 1200 ninja and i can idle flip easy
Do you do total loss dual coil setups like pictured above?Questions about Zeeltronic ignitions? We import and stock them here: https://www.fastfromthepast.com/ignitions
We do them here in California, unfortunately with the passing of Art (ET) we have had a slight hiccup in getting the vital parts for the system. We are working to fix this issue and help fill the void of MSD's discontinuation. We had quite a bit of interest at World Finals and even had some offers to help pickup manufacturing logistics for some parts.Do you do total loss dual coil setups like pictured above?
Yes its all running I have put through over 20 tanks in it and it rocksAny updates on the 62t zeel?
Is it plug & Play ?Yes its all running I have put through over 20 tanks in it and it rocks
You will be very happy with it.
$365.00 plus shipping. Totally different USB Cable its $65How much? And do they use the same configuration cable as the 760 units
Yes I guess so. I have been running one for about 20 tanks and its awesome no kick back like seen on other ignitions and great power as well. Its very reliable which is unheard ofCool! I guess this is the new Advent?
Looking good! Finally!! Maybe you should start a new seperate thread with this new 62T style Zeeltronics CDI? This is sorta off the beaten path here.Its Finally Time! The NEW Zeel Y62T is in stock for immediate shipment!
this is a Fully Programable Zeel CDI, Just like the GP760 versions, only its direct plug and play
on your 61X / 62T based Yamaha Superjet! Carries 2 on board curves that can be switched on the fly.
I have been testing one on my personal boat since April. Have tried it with both 61x & 62T flywheel / stators,
lightened and std uncut, and all known Alum Charging flywheels on the market. All ran flawlessly! Some minor static angle adjustment was required on the TBM alum charging, but only two degrees. The Future is here!
please email me directly at paul@lehrperformance.com for fastest response! Pre-Paid and waiting list orders will be shipped first!View attachment 418087View attachment 418088
Your right! It was my plan to do that and post in the new products section. But as with most one man shops,Looking good! Finally!! Maybe you should start a new seperate thread with this new 62T style Zeeltronics CDI? This is sorta off the beaten path here.
Does it come pre-programmed with a "MSD Enhancer" kinda curve as a baseline?
Which Briggs coil do you use for the 2 cylinder setup? How is spark compared to oem ?You can run any coil wired in series. I run Brigs and Stratton coils.View attachment 415520View attachment 415521View attachment 415522
