Both Zeel versions pull a portion of there energy off the charging side of the circuitry when run as TL, its only as good as the battery powering it. And looses energy, the longer its run. Not the case with charging. I proved it on my personal boat some time ago while running the A02T on TL. Went to go on a surf trip and just changed to a lightened charging flywheel. Lost my tune? Was lean. Swapped back to TL flywheel, all was good. Went back to charging, and rejetted. Ran much better than with the TL! Of course, I could tell the difference in Flywheel weight, but that was it.
this past Daytona, I delivered a new TPE 1105 build to a client. It ran a Y62T with Jetinetics flywheel. Boat is extremely Flatwater capable! Have setup several others now the same. All Run very good! Please know, this is Not yet a replacement for MSD TL. However, getting closer all the time. Im learning and getting better with my tunes.
this is where Im finding big gains
