davidescu_radu
sea riders
- Constanta,Romania
At this stage I do not know of a unit that will work with thatHi! Where can i ask if any zeel cdi will work with old riva/rad total loss stator/flywheel? - only one sensor!?
Would I be able to run my 62t stator flywheel with a zeeltronic pdcis-ao2tNews in from zeeltronic
we are Just finishing new PDCIS-02T for GP760. It will have latched stop switch and automatic power down. CDI will draw only 0.5mA in power down, that means it does not need to be switched off any more...it will need few years to drain 19Ah battery.
Price is 175 euro which is about 198 usa dollars. Plugs into the stock 760 plug
what's the latched stop switch? on the new pdcis-02tAt this stage I do not know of a unit that will work with that
Lateched means when you push the stop switch it stay off, before you used to have to hold the switch down until it stoppedwhat's the latched stop switch? on the new pdcis-02t
I'm running one on a php898. I used the curve that was recommended to me by Zach, last I knew he is selling zeeltronic, hit him up.
Just run the exact curve you had on the MSD. It will perform exactly the same. Make sure total timing is in by 1500-1800 rpm. If you aren’t sure what’s on the MSD you will have to measure your static timing and then check your dip switches against the MSD manual. Happy to help if you aren’t sure how to do that.
Are you the same person I am talking to in face bookSo I randomly loss spark on my 760 that has a zealtronic cdi....ski has been sitting for a month due to winter season, and I go and start it up from time to time. Started before I put it away and now it has no spark. Any way of testing it? Or suggestions.
Not sure....Chris M? Would be dope for you to add me lol I have questions.Are you the same person I am talking to in face book
One thing to note about these Battery-Powered CDIs, is that the Battery must supply enough Voltage for BOTH the DC-CDI AND STARTER at the SAME TIME during starting attempts.
So 9 Volts minimum required for the Zeeltronic CDI doesn't always mean that a Battery at 9 Volts can start the Engine. The Starter draws a lot of Current and Voltage at Start-Up.
Too weak a Battery and the Starter will not move the Pistons fast enough to create enough Compression to support Combustion even with a Spark present.
An even weaker Battery won't even provide enough Voltage to produce a Spark.
Don't buy cheap Batteries and keep the Battery charged.
Most Batteries under $100 bucks generally are not up to the Task.
Already went thru this Scenario. My spare 760 Engine with A02T Zeel would start every couple of weeks off the same Battery until it didn't. Noticed the Cranking Speed was a bit lazy. Sprayed Starting Fluid inside the Cylinder thru the Spark Plug Hole and nothing, not even a cough or a chug. But the Starter would engage and spin the Crank.
Put the Battery Charger on the Battery with a 2 Amp trickle charge and right away hit the Start Button and voila, the Engine started right away. Revved nice and crisp.
So, in my case, the Battery was too weak to provide enough juice to start the Engine.
