This should be good for you.
Chris.
Chris.
Anyone have a curve set up fpr
I have a Rickter FS 2 with the following motor info:
6 mil stroker motor with 89 mm 951 Pistons. Probably makes it around a 930?
Im running high compression around 225 in each cylinder. I run race fuel because of the high compression.
I run a b pipe and would like to advance the timing around 28 degrees
Anyone have a curve they could show me to run in my Epic?
Thanks
Peter
